My settings are not saved:
Environment Checks
<table class="table">
<thead>
<tr>
<th class="group-false">Item</th>
<th class="group-false" data-sorter="tickcross">Status</th>
<th class="group-false">Advice</th>
</tr>
</thead>
<tbody>
<tr >
<td>PHP Version</td>
<td><span class="glyphicon glyphicon-ok"></span></td>
<td>PHP version 5.3.3 or later required. Detected 5.3.27</td>
</tr>
<tr >
<td>File System Permissions</td>
<td>Write access required for settings.php and install.php</td>
</tr>
<tr >
<td>MySQL database (PHP MySql)</td>
<td>MySQL support must be enabled in PHP.</td>
</tr>
<tr >
<td>MySQL database (PDO MySql)</td>
<td>PDO support with MySQL drivers must be enabled in PHP.</td>
</tr>
<tr >
<td>JSON Extension</td>
<td>PHP JSON extension required to function.</td>
</tr>
<tr >
<td>SOAP Extension</td>
<td>PHP SOAP extension required to function.</td>
</tr>
<tr >
<td>GD Extension</td>
<td>PHP GD extension to function.</td>
</tr>
<tr >
<td>Session</td>
<td>PHP session support to function.</td>
</tr>
<tr >
<td>FileInfo</td>
<td>Requires PHP FileInfo support to function. If you are on Windows you need to enable the php_fileinfo.dll in your php.ini file.</td>
</tr>
<tr >
<td>PCRE</td>
<td>PHP PCRE support to function.</td>
</tr>
<tr >
<td>Gettext</td>
<td>PHP Gettext support to function.</td>
</tr>
<tr >
<td>Calendar Extension</td>
<td>PHP Calendar extension to function.</td>
</tr>
<tr >
<td>DOM Extension</td>
<td>PHP DOM core functionality enabled.</td>
</tr>
<tr >
<td>DOM XML Extension</td>
<td>PHP DOM XML extension to function.</td>
</tr>
<tr >
<td>Mcrypt Extension</td>
<td>PHP Mcrypt extension to function.</td>
</tr>
<tr >
<td>Allow PHP to open external URLs</td>
<td>You must have allow_url_fopen = On in your PHP.ini file for RSS Feeds / Anonymous statistics gathering to function.</td>
</tr>
<tr >
<td>DateTimeZone</td>
<td>This enables us to get a list of time zones supported by the hosting server.</td>
</tr>
<tr >
<td>ZIP</td>
<td>This enables import / export of layouts.</td>
</tr>
<tr >
<td>Large File Uploads</td>
<td><span class="glyphicon glyphicon-exclamation-sign"></span></td>
<td>You probably want to allow larger files to be uploaded than is currently available with your PHP configuration.<br />We suggest setting your PHP post_max_size and upload_max_size to at least 128M, and also increasing your max_execution_time to at least 120 seconds.</td>
</tr>
<tr >
<td>Internationalization</td>
<td>International Support for formatting Dates, Numbers, etc.Translations will still function without this PHP module, however dates, times and numbers will not be shown in your locale.</td>
</tr>
<tr >
<td>cURL</td>
<td>cURL is used to fetch data from the Internet or Local Network</td>
</tr>
</tbody>
</table>
LOG Dump
Date,Page,Function,Message
"2015-10-26 22:29:06",“User”,“DisplayList”,“SQL: SELECT display.displayid, display.display, displaygroup.description, layout.layout, display.loggedin, IFNULL(display.lastaccessed, 0) AS lastaccessed, display.inc_schedule, display.licensed, display.email_alert, displaygroup.DisplayGroupID, display.ClientAddress, display.MediaInventoryStatus, display.MacAddress, display.client_type, display.client_version, display.client_code, display.screenShotRequested, display.storageAvailableSpace, display.storageTotalSpace, currentLayout.layout AS currentLayout, currentLayout.layoutId AS currentLayoutId FROM display INNER JOIN lkdisplaydg ON lkdisplaydg.DisplayID = display.DisplayID INNER JOIN displaygroup ON displaygroup.DisplayGroupID = lkdisplaydg.DisplayGroupID LEFT OUTER JOIN layout ON layout.layoutid = display.defaultlayoutid LEFT OUTER JOIN layout currentLayout ON currentLayout.layoutId = display.currentLayoutId WHERE displaygroup.IsDisplaySpecific = 1 ORDER BY display. Params: array (
Display Dump
Settings Dump
Setting: MEDIA_DEFAULT - Value: private
Setting: LAYOUT_DEFAULT - Value: private
Setting: defaultUsertype - Value: User
Setting: userModule - Value: module_user_general.php
Setting: defaultTimezone - Value: Europe/Amsterdam
Setting: mail_to - Value: mail@yoursite.com
Setting: mail_from - Value: mail@yoursite.com
Setting: jpg_length - Value: 10
Setting: ppt_length - Value: 10
Setting: swf_length - Value: 10
Setting: audit - Value: audit
Setting: LIBRARY_LOCATION - Value: /var/www/vhosts/schoolmuurkrant.nl/xibo_library/
Setting: HELP_BASE - Value: http://www.xibo.org.uk/manual/en/
Setting: PHONE_HOME - Value: On
Setting: PHONE_HOME_URL - Value: http://www.xibo.org.uk/stats/track.php
Setting: PHONE_HOME_DATE - Value: 0
Setting: SERVER_MODE - Value: Production
Setting: MAINTENANCE_ENABLED - Value: Off
Setting: MAINTENANCE_EMAIL_ALERTS - Value: On
Setting: MAINTENANCE_KEY - Value: changeme
Setting: MAINTENANCE_LOG_MAXAGE - Value: 30
Setting: MAINTENANCE_STAT_MAXAGE - Value: 30
Setting: MAINTENANCE_ALERT_TOUT - Value: 12
Setting: SHOW_DISPLAY_AS_VNCLINK - Value:
Setting: SHOW_DISPLAY_AS_VNC_TGT - Value: _top
Setting: MAINTENANCE_ALWAYS_ALERT - Value: Off
Setting: SCHEDULE_LOOKAHEAD - Value: On
Setting: REQUIRED_FILES_LOOKAHEAD - Value: 172800
Setting: REGION_OPTIONS_COLOURING - Value: Media Colouring
Setting: LAYOUT_COPY_MEDIA_CHECKB - Value: Unchecked
Setting: MAX_LICENSED_DISPLAYS - Value: 0
Setting: LIBRARY_MEDIA_UPDATEINALL_CHECKB - Value: Unchecked
Setting: USER_PASSWORD_POLICY - Value:
Setting: USER_PASSWORD_ERROR - Value:
Setting: MODULE_CONFIG_LOCKED_CHECKB - Value: Unchecked
Setting: LIBRARY_SIZE_LIMIT_KB - Value: 0
Setting: MONTHLY_XMDS_TRANSFER_LIMIT_KB - Value: 0
Setting: DEFAULT_LANGUAGE - Value: en_GB
Setting: TRANSITION_CONFIG_LOCKED_CHECKB - Value: Unchecked
Setting: GLOBAL_THEME_NAME - Value: default
Setting: DEFAULT_LAT - Value: 51.504
Setting: DEFAULT_LONG - Value: -0.104
Setting: SCHEDULE_WITH_VIEW_PERMISSION - Value: No
Setting: SETTING_IMPORT_ENABLED - Value: 1
Setting: SETTING_LIBRARY_TIDY_ENABLED - Value: 1
Setting: SENDFILE_MODE - Value: Off
Setting: EMBEDDED_STATUS_WIDGET - Value:
Setting: PROXY_HOST - Value:
Setting: PROXY_PORT - Value: 0
Setting: PROXY_AUTH - Value:
Setting: DATE_FORMAT - Value: Y-m-d H:i
Setting: DETECT_LANGUAGE - Value: 1
Setting: DEFAULTS_IMPORTED - Value: 1
Setting: FORCE_HTTPS - Value: 0
Setting: ISSUE_STS - Value: 0
Setting: STS_TTL - Value: 600
Setting: MAINTENANCE_ALERTS_FOR_VIEW_USERS - Value: 0
Setting: CALENDAR_TYPE - Value: Gregorian
Setting: DASHBOARD_LATEST_NEWS_ENABLED - Value: 1
Setting: LIBRARY_MEDIA_DELETEOLDVER_CHECKB - Value: Unchecked
Setting: USE_INTL_DATEFORMAT - Value: 0
Setting: PROXY_EXCEPTIONS - Value:
