How about allowing the scheduling of a layout / media to be repeated every 4 media, 5 media etc … or every time interval.
User Story
I know it’s possible in a layout or in a group of layouts to insert a media every x other media, repeating it several times to achieve this goal.
However, it would be much more practical if this were only possible by setting this range in the layout or group of layouts.
I suppose they could think in case a media was scheduled for a certain time, and that this moment coincided with the defined interval, in this case the user could choose who would have priority, scheduling by schedule, or scheduling by interval.
The interaction is:
EX1; You can schedule an “X” media to be displayed in the media range,
Every 4 media displayed, the “X” media would be displayed.
EX2; You can schedule “X” media to be displayed in minutes, hours, etc.
Each “Y” Period would display the “X” media.
“In this case, if the time set for display matches the display of another media, the” X “media would only be displayed after the current media completion”
This function is important to be able to add the constant display of media quickly, without the need to access layout by layout adding the desired media.
Note: It was NOT POSSIBLE to obtain this result using the “repeats” option in AGENDAMENTS.
Even if the repetition was defined every 1 minute, the media was repeated hundreds of times in a row, only after the rest were played.
Another issue is that when I select the “AWAYS” option the “REPEATS” option disappears.
Using the Repeats option (as you have mentioned) would mean that the Layout itself would repeat every minute is has been scheduled for. With a schedule set to Always the Repeats functionality is redundant.
With the release of the v2 CMS we have Playlists which allows users to add/edit media without the need to access Layouts.
