Server not accessible after restarting
I installed Xibo on Windows using Docker and was accessing the server with no problem using localhost. I was attempting to set it up to access over the network. After a restart I can no longer access the server. I tried restarting using “cd /opt/xibo/” then “docker-compose up -d” as was suggested in another post. Below is the result, which suggests it is already running.
xibo_cms-memcached_1 is up-to-date
Starting xibo_cms-web_1 …
Starting xibo_cms-xmr_1 …
xibo_cms-db_1 is up-to-date
Starting xibo_cms-web_1 … error
WARNING: Host is already in use by another container
Why is the server not accessible now?
Still accessible from localhost?
No. It’s not, but I’m trying to close this thread because I’ve posted a new message. I started from scratch with a new installation of Linux server on bare metal, thinking it would be better not to do it on Windows with WSL. I have a new problem now. Here is the link: error-while-fetching-api-version
I’m also having trouble closing this thread. I think there is supposed to be 3 dots somewhere to click to get to the menu, but I don’t see the dots anywhere. Thanks for your help.
Darren
