Searching for a high brightness monitors
Well I am a new Xibo new user I have recently tested Android 14 tv boxes with Xibo and it works fine. I have been using google store downloader to install the apk and it was working fine even with HDTV 5G TV wireless transmitter with portable monitor. I understand that monitors and tv are not the same particularly if they are instaled in places where there is partial sun or direct sun. So I believe that we should share our experience with 1000 to 2000 nits monitors. These monitors are quite expensives, I am still looking for a 24/27 inches monitor. If you have any idea please let me know. Regards.
Hi!
I also use a professional LG 88" display, but its brightness is only about 700, and it’s also difficult to see in direct sunlight.
I assume that a bright picture in direct sunlight would require LED display a minimum 2000 or a high-brightness display like the LG 55XS4J-B.
