Scroll Homepage in Xibo
im Peter, and a new Member of the Xibo Community.
My first question is, can i scroll a Homepage up and down in a Layout?
An example , a friend has a car dealership and would like to play his side with the offers in Xibo . However, since the website is longer than the resolution this would be scrolled …
no idea to scroll a http hompage up and down?
I suppose one could create a scrolling view of the webpage, using JavaScript in an embedded media type. I’ll leave that up to others to experiment with.
Meanwhile, certainly you can hike the webpage up in steps using the following method.
In the region’s timeline, place multiple webpage media types. Set their Options to “Manual Position”, then set the Offset Top for each to successively larger values, from 0 to however much you need until the bottom of the page is visible in the last one.
