Scheduling with Dayparting and exemption
CMS Version 3.03
Specify the full CMS version you are using, including the revision number.
Player Type WINDOWS
Include the Player type you are using.
Player Version 3.03
Include the full version, including the revision number.
Please provide full details as to the issue you are experiencing, include screenshots where possible.
We are using Google apis to pull in map updates and don’t want it to run on the weekends to stay within our free tier. We have one video we want to play four times an hour but we cannot figure out how to enable it with a dayparting exemption because there is no option to allow it to use the repeat option & enable a dayparting option when you have something set to repeat every 15 minutes. how to play a video every 15 minutes BUT not play on the weekends. seems easy right?
