I have a problem with a pc. Now it shows black screen, can hear sounds of videos playing. Info Screen, server connection and xmr connection is working fine.
The problem is maybe about sound card, video card I dont know. Maybe one video file had problem while starting video play. I think if I restart the app, everything will be fine.
But the main problem is, I cannot see the problem on cms. In Cms it shows a screen shot without problem (because if there is a problem, it cannot get new screen-shot)
Here is sshot:
If you just look Cms, you can say everyhing is great on client. But client currenty black screen.
If you check the log of the Display, it shows Schedule Error,
Here You can see task manager screen for info.
Summary:
- It needs to show screenshot time on cms, so user could understand when the correct screenshot taken.
- If memory overflow, video card error, sound card error happens, the watchdog should restart application, maybe restart the pc.
Michael
