CMS Version 4.0.4
I was able to quickly create and save user without setting up the homepage
This results in saving NULL in “user” table in the database for “homePageId”
from this point, no users are visible in the Users pagem and this error can b found in logs under debug mode:
Xibo\Factory\UserGroupFactory::getHomepageByName(): Argument #1 ($homepage) must be of type string, null given, called in /var/www/cms/lib/Controller/User.php on line 316
Modifying in db , ‘users’ table for the relevant userId the homePageId to ‘statusdashboard.view’ - solve the problem.
