Is there a Samsung Tizen Frame TV that someone have successfully installed xibo client?
Hi Sigurd_Fyllingsnes, welcome to the community!
Xibo for Tizen requires SSSP (Samsung Smart Signage Platform) version 5 or newer, which is not included in the Samsung smart TV range. Because of this, the Tizen Frame range is not compatible with the player.
Below is a link to our supported hardware guide, which includes a list of all known models that meet the requirements.
https://xibo.org.uk/docs/setup/tizen-list-of-supported-monitors
If you find a model that is not listed and is running SSSP 5 or newer, please let us know and I can investigate if the model is supported.
Many thanks and hope you manage to find a suitable supported display for your Xibo for Tizen players.
