I could not find any sample code to add displayin API documentation. Please if anyone can help me to add a display through API.
Display with installed Xibo player needs to make connection to the CMS and then it will create a new display record.
I require the ability to add the display through API from my custom application and not the player. RegisterDisplay method mentioned in XIBO documentation on http://xibo.org.uk/manual-tempel/en/xmds.html seems to do that. But I could not find any sample code for that.
XMDS is designed to be called from the Player - you will find examples in the Player source code. It is a SOAP webservice and sending a HTTP request with a payload like the below will do it:
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:tns="urn:xmds" xmlns:types="urn:xmds/encodedTypes" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<tns:RegisterDisplay>
<serverKey xsi:type="xsd:string">{{serverKey}}</serverKey>
<hardwareKey xsi:type="xsd:string">{{hardwareKey}}</hardwareKey>
<displayName xsi:type="xsd:string">{{displayName}}</displayName>
<clientType xsi:type="xsd:string">{{clientType}}</clientType>
<clientVersion xsi:type="xsd:string">{{clientVersion}}</clientVersion>
<clientCode xsi:type="xsd:int">{{clientVersionCode}}</clientCode>
<macAddress xsi:type="xsd:string">{{macAddress}}</macAddress>
</tns:RegisterDisplay>
</soap:Body>
</soap:Envelope>
You can discover this information via the WSDL as described in the manual page you linked to.
As @peter said, the CMS API doesn’t support adding displays.
