Hey,
im trying to set xibo (docker) to auth via saml again authentik as IDP, here my config:
<?php
# If you need to add custom configuration settings to the CMS settings.php file,
# this is the place to do it.
# For example, if you want to configure SAML authentication, you can add the
# required configuration here
#$authentication = new \Xibo\Middleware\SAMLAuthentication();
$samlSettings = array (
'workflow' => array(
// Enable/Disable Just-In-Time provisioning
'jit' => true,
// Attribute to identify the user
'field_to_identify' => 'UserName', // Alternatives: UserID, UserName or email
// Default libraryQuota assigned to the created user by JIT
'libraryQuota' => 1000,
// Initial User Group
'group' => 'Users',
// Home Page
'homePage' => 'icondashboard.view',
// Enable/Disable Single Logout
'slo' => true,
// Attribute mapping between XIBO-CMS and the IdP
'mapping' => array (
'UserID' => '',
'usertypeid' => '',
'UserName' => 'uid',
'email' => 'mail',
// Settings for the PHP-SAML toolkit.
// See documentation: https://github.com/onelogin/php-samlsettings
'strict' => false,
'debug' => true,
'idp' => array (
'entityId' => 'https://auth.example.services/application/saml/xibo/sso/binding/init/',
'singleSignOnService' => array (
'url' => 'https://auth.example.services/application/saml/xibo/sso/binding/redirect/',
'singleLogoutService' => array (
'url' => 'https://auth.example.services/application/saml/xibo/slo/binding/redirect/',
'x509cert' => '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',
'sp' => array (
'entityId' => 'http://xibo.example.de/saml/metadata',
'assertionConsumerService' => array (
'url' => 'http://xibo.example.de/saml/acs',
'url' => 'http://xibo.example.de/saml/sls',
'NameIDFormat' => 'urn:oasis:names:tc:SAML:2.0:nameid-format:emailAddress',
'x509cert' => '',
'privateKey' > '',
'security' => array (
'nameIdEncrypted' => false,
'authnRequestsSigned' => false,
'logoutRequestSigned' => false,
'logoutResponseSigned' => false,
'signMetadata' => false,
'wantMessagesSigned' => false,
'wantAssertionsSigned' => false,
'wantAssertionsEncrypted' => false,
'wantNameIdEncrypted' => false,
but after succesfull login i got this:
and console brings me this:
does anyone got it work?
