3 R307.0
Hopefully this is the right place to post for this particular issue.
After enabling Single Sign-On, all players stop communicating with the CMS, show the XML error in the title, and wont connect or download new media.
Turning the logs to Debug, I get the following log entries:
| 1133946 | 71145e8 | 2023-04-04 08:24 | PLAYER | POST | ERROR | Display | [RequiredFilesAgentThread] ScheduleAgent - Run | Exception in Run: Response is not well-formed XML. |
| 1133945 | 71145e8 | 2023-04-04 08:24 | PLAYER | POST | ERROR | Display | [StatAgentThread] StatAgent | Run: Exception in Run: Response is not well-formed XML. |
| 1133944 | 71145e8 | 2023-04-04 08:24 | PLAYER | POST | ERROR | Display | [FaultsAgent] FaultsAgent - Run | Exception in Run: Response is not well-formed XML. |
As soon as I remove the Single Sign-On settings, all displays start to check in and download new media if available. Nothing else has changed in my environment, its just whenever I enable SSO. My SSO setup can be found in my other post here: Azure SSO Setup - #3 by itsjustbrianyo
Thanks in advance!
Provide screenshots where possible!
