We have a device with Asus Tinker Board 16 GB external memory. We want to broadcast live TV from rtsp: //10.33.200.230: 8080 link.However, the screen remains black after loading.
Cannot display video. Uri = rtsp: //10.33.200.230. What = -1003. Extra = -5.
we get the error
-1003 is Android Media Server’s code for “Cannot connect”.
Your Uri appears to be rtsp://10.22.200.230 but you’ve said it’s in port 8080 so you’d need your Uri to be rtsp://10.22.200.230:8080 - assuming no path is required.
If it’s RTSP then the correct URL would be rtsp://10.33.200.230:8080 based on what you’ve put in your question.
If you think it’s https://10.33.200.230 then that doesn’t sound like an RTSP stream to me. I would check that it is really an RTSP stream you’re consuming and not something else.
