Can you please indicate why this feed https://culemborgsecourant.nl/rss is not working?
We checked it with the validator and no problems
Thank you for your message. I have been testing with your RSS feed link and I also cannot return any results. I decided to create a Layout and audit it so I could see what was happening when the data was requested. Below are the logs I found:
The feed is returning a forbidden response, which is likely due to the feed being configured to deny or forbid the user agent type that Xibo uses to access feeds. I would recommend contacting the persons responsible for the Feed and if possible, asking them to allow curl User agents access to your feed.
If the issue persists after doing this, please let me know.
Thx, i will let you know
We have solved it,thx for the reply message!
Excellent news! Glad it’s all sorted now and you were able to resolve the issue.
