Hi all,
as in topic, I need to rotate a localvideo.
Unfortunately there is no “rotation” or “custom css” attribute in the widget “local video” so I need your help.
Any suggestion ?
Thanks,
Massimo
Hi all,
Any suggestion ?
Thanks,
Massimo
Welcome to the Xibo Community.
What version of Xibo CMS?
You use playlist or layout?
Thanks for your answer ProServ
I’m a newbie.
I’m using xibo ver.4.011 and layout.
You cannot rotate a video.
If your video is in portrait, I assume that the screen is also in portrait.
You therefore need to set the screen to portrait in your display profile and set your layout in portrait too.
But maybe you could post a screenshot of your layout?
