I am looking to configure specific access restrictions for a module within Xibo. Specifically, I want to limit the visibility of the Ticker module on layout to certain user groups. For instance, I want to make the Ticker module unavailable to Group 1, while ensuring that it remains accessible to all other groups. My goal is to customize the module permissions in such a way that only certain groups have access to this content, allowing for more targeted control over the display options across different user groups. How can I achieve this within the Xibo ?
Hi, currently you can only enable/disable a module for all users of the CMS. I believe that having the option to restrict access by user/user group has been mentioned by users before and so I will record this internally for further discussion.
Thank you for posting
Thanks for the nice reply Natasha
