For the original poster (OP) to fill in:
Introduction
Add view privileges to resolution similar to layout privileges
ability for admin to either assign a resolution or set of resolutions to a user, or ability to set view permissions to resolutions.
User Story
I run many digital displays on this system. they are all different company’s.
they all have custom resolutions that i put their name in currently like 64x288 burger king.
currently when they create a layout they need to assign the custom resolution to their layout for formatting.
but if i have a 128x288 McDonalds resolution, now burger king can see McDonalds sign is on the same network.
For the dev team to fill in:
Status
The current status and the username of the:
- Reporter
- Drafter
- Implementer
Implementation
A broad description of the changes required.
Effected Software
Which parts of Xibo are effected
DB Schema Changes
Any necessary DB Schema Changes
