Thx for quick answer. Have one more question, trying to setup a new PC with Xibo. Have some problem with the resolution, PC`s resolution is 1920*1080, and I have set the layout at the same. But take a look at the picture, it is just a small bit off the homepage that is displaying. Windows 7 is the operating system
Assuming the region covers the whole layout in the designer in the CMS, then it’s likely you’re missing some files on the Player.
On the CMS, go to the Modules page and click the Verify All link. Then give the Player some time to download any missing files and then restart it.
Thx for the advice, have verify all. But still the same after 10 min. I don`t get it, works fine on other computers. Same tv-monitor, same computer model, same operating system.
