my bad! Column Type wasn’t set to remote… Now it’s updating correctly.
I experience the data to be displayed with a . as decimal separator.
Any chance to change that according to the location settings of the display? Here in Germany I would like to have , as decimal separator as well as . as thousand separator.
I would use another column to do this (one that is not remote), using the FORMAT function. The first argument in the function is the name of the number column that you want to format the data from; the second argument is the number of decimal places you want the number to have; and the third argument is the locale value which dictates the decimal and thousand separators.
