I’m trying to use dataset to get JSON data. However, the only authentication method is via an API Key without any username. I assume I should use Bearer authentication, however, I could not get any request back. Am I doing something wrong here?
I can send the API Key for your testing if required. Thank you.
To add:
I was able to get the query using postman. The API Key was required to be key under Headers on Postman, as it’s using the inherit auth from parent method.
Is there a way i can key this API Key on the remote data set?
Ola, se preferir pode me enviar a chave pra que farei um teste e também posso configurar pra você
