And in Data root I wrote “items” under which is the following line:
“date”: “2024-09-06T18:39:00+03:00”
From it I want to pull the following part: “2024-09-06T18:39:00+03:00”.
I also defined Column when in “heading” and in “Remote Data Path” I entered “date”, and in “Column Type” I chose Remote.
I see that the synchronization is carried out according to the synchronization times, but I do not see that data is received.
