2.3.7 on RHEL docker
I’m trying to create a remote data set pointing to another container (api-container) on the same server. I added the container to the Xibo_default docker network. If I do a curl -v from the xibo_cms-web container to the api-container I see the data.
But when putting the same URL from the curl command in the data set I get a proxy error:
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request POST /dataset/remote/test.Reason: Error reading from remote server
Why?
