We are trying to close Xibo for Android when connecting with Team Viewer. It is required for maintenance etc. We connect with team viewer but we can’t exit out of Xibo.
Is it possible?
Right click on Xibo to close it (assuming you’ve not made it the launcher).
Then go in to System Settings - Apps and find Xibo, and use the Force Stop/Force Close button. Xibo won’t then restart itself automatically.
You’ll need to ensure you start it again manually before you disconnect from your session.
