Morning,
I’ve just started getting this error when I try and register a display
Client found response content type of ‘application/octet-stream’, but expected ‘text/xml’.
The request failed with an empty response.
We’re using 1.4.2
Morning,
We’re using 1.4.2
it would usually indicate a wrong CMS address, are you sure that everything is correctly entered?
I’d also recommend update to 1.7 version.
thanks,
Peter
