Hello good morning, I would like to know what TV’s compatible with the Xibo system, I’m starting and gostria to clear these doubts. Anyone with Android operating system work?
I tested on Sony Android TV and it is working good. You need Android tv at least version 6 for good working xibo player. It is depending on what you want to use.
If you want to remote power on/power off display i can suggest to use android box with simple TV and working HDMI-CEC commands.
