Hi caminin,
Did you test the H96 max RK3328 or the H96 max RK3399 ?
Hi caminin,
Learned that H96 pro+ has a little issue, even through it does have a great specs and power, it does not play in portrait mode. I have tried many apps. No luck, so only landscape.
Before you buy it, check with seller if it supports a Portrait mode. Its quite a needed feature.
Over the past year or so, some of our Minix’s were starting to fail in the harsh shop environment. We’ve since changed each one of our players over to DSDevices DSCS9 and we have been extremely happy. Better pricing and better Xibo support (they actually know what it is!).
Currently only $90/ea.
Model No: DSCS9
CPU: Amlogic S912 64-Bit octa-core
ARM Cortex A53 processor @ up to 2.0GHz
GPU: ARM Mali-T820MP3 GPU up to 750MHz(DVFS)
RAM: 2GB DDR3
Internal Storage: 16GB eMMC
OS: Android 6.0.1
HDMI: HDMI 2.0a up to 4K @ 60Hz
WiFi: Dual Band WiFi 802.11 b/g/n/ac 2.4 and 5.0 GHz
CEC (Consumer Electronics Control)
XIBO - Pre-installed not licensed
TeamViewer - Pre-installed not licensed
Screen rotation
Auto power on
Dimensions: 10.8cm x 12.2 cm
Warranty: 1 Year RTB
