Hi, I hope someone can help me with this. I currently have the CMS installed on a Windows IIS server and after carrying out the upgrade from 2.3.9 to 3.0.3 I can no longer see the layouts that I had created before the upgrade. All the Displays are listed fine and I can see the default layouts that are assigned to them appear to be still listed there. However, in the layouts section I only see the root folder. I have played with the filters but nothing appears.
I have since checked the database tables using myphpadmin and I can see the layouts are listed there. I have also tried to create a new layout as a test and after saving this test layout it doesn’t appear either. I have cleared the cache on my browser and also tried another browser.
I am guessing I may need to run a command against the database to restore this. Any ideas on how I could fix this?
