Reboot with android command
why does it want alpha characters on restart with andorid command? can you help with this?
Hi, we have a guide here on How to set up a Reboot command on Xibo for Android which you may find helpful.
  • hi, thank you, I know back, but there is a problem, I’m using cms 3.3.3 and I’m having a problem adding alpha characters, what should I do about it
Uploading: yeniden başlatma.JPG…
