I think if you added the ability to set Transitions by a Default Setting like Random instead of having to set each image one at a time this would be GREAT
Yes. And also a default fade in fade out time would be great
I’ve moved your topic to the features category, so we can consider it for future development - it is not guaranteed that it will be implemented though, but some sort of default values for transitions to speed up the process could be something that we can consider in the future.
