Hello Xibo,
we tried to upgrade our Xibo clients (Win 10, 22H2) to R306.2, but the setup ended wit an error:
setup ended prematurely because of an error
This is reproducible, version 305 works without errors.
Hello Xibo,
Same problem for me.
Thanks.
306.3 the same problem and 305.1, 304.1 too
Not sure, if that’s the same issue or not (mine was with version R305.1), but I had similar error and it was caused by too new Visual C++ library already present in my computer (Xibo tried to install older version during installation and failed).
Same Too,
when i test in version 3r305 can instal and work normal
I can install now
Here, how i can install :
hope its help
Xibo released new version of Windows player. It should solve at least Visual C++ library issue (if you have newer version installed). During my testing it gave an error, when it found newer C++ library, but allowed me to choose, if I want to continue with installation or not.
