Proxy configuration using CEF
I know CEF wont be supported but is CEF compatible with the Proxy configuration (user/pwd/domain) defined inside the agent config ?
Xibo 1.7.9
Sorry - but no - the version of CEFSharp we built the beta against didn’t have support for manual proxy configuration. I think that it can be done with later versions of CEFSharp - so if you wanted to get into the code to build that you could.
