I second Frederic_Horcholle’s advice, please try logging into your CMS from the machine running your player to see if any errors are returned. You should also make sure that the time, date and time zone are set correctly on your machines as this can cause connection issues.
I noticed on the login page for your CMS that you are using CMS version 2.3.4. Could you confirm the version of Xibo for Windows that you are using? If it is the latest player, please can you uninstall that player and instead install R258 (Windows 10 required) onto one of your machines and confirm if the issue persists? You can download a copy of R258 from here. I would also be interested to know if the error message is the same when using R258.
