Hi
as I was at 1.8.13 before I did a completly reset. New machine, new actual 4.0.9 xibo and uninstall all old client software/install actual windows player
So now I had the first problem with fonts.css, but that I fixed via uploading just arial.ttf. Then I have 2 layouts - 1 info layout for three screens and one welcome layout for the fourth one
the first display is showing the info layout correctly, the two other ones not. they simply don’t show widgets and not even all pictures. But at manage page it’s all completly downloaded and green. Ive already manualle removed the xibo library folder at that client multiple times
the welcome display always show only the splash screen. first it had a problem with one jpg. it was always red and didnt download. removed as well the local library often and then changed that to png with no luck and again to jpg with a lower file size of 600kb. now it doesnt even appear anymore in the manage screen and still only splash screen.
one of these display shows now everything beside of the ticket… there is just “Enter text…”
my welcome displays with the always splash screen… Ive changed it to an another layout-> it works. changed it to info layout->it works. So I deleted my welcome layout, made it new via the same template as all other layouts have as well->again only splash screen -.-
okay. looks like I solved this problem via reducing the size of that picture again. it’s now at 312kb and now that works for that display
what could I do anymore?
one more thing… I have a lot of media files used in my template. Those are all accessible in the templates and layouts. But when I click on the left menu directly media I don’t see anything in none folder. is that normal?
