It’s doesn’t work anymore…
Ubuntu 18.04 up to date on 3 different pc
Nom Version Révision Suivi Éditeur Notes
core18 20200724 1885 latest/stable canonical✓ base
gnome-3-28-1804 3.28.0-19-g98f9e67.98f9e67 145 latest/stable canonical✓ -
gtk-common-themes 0.1-36-gc75f853 1506 latest/stable canonical✓ -
snapd 2.47.1 9721 latest/stable canonical✓ snapd
xibo-player 1.8-R5 50 latest/stable xibosignage -
first : dell 760 with nvidia gpu :
oct. 23 12:25:35 fst-o-f-xibo2 player[4617]: player: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
oct. 23 12:25:35 fst-o-f-xibo2 xibo-player[4547]: Player exited with code 1
Sometimes i can play 2 video and the player stop to work randomly :
oct. 23 12:32:06 fst-o-f-xibo2 player[5170]: The program 'player' received an X Window System error.
This probably reflects a bug in the program.
The error was '143'.
(Details: serial 395 error_code 143 request_code 139 (RENDER) minor_code 7)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the GDK_SYNCHRONIZE environment
variable to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
oct. 23 12:32:06 fst-o-f-xibo2 xibo-player[4547]: [xcb] Unknown sequence number while processing queue
oct. 23 12:32:06 fst-o-f-xibo2 xibo-player[4547]: [xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
oct. 23 12:32:06 fst-o-f-xibo2 xibo-player[4547]: [xcb] Aborting, sorry about that.
oct. 23 12:32:06 fst-o-f-xibo2 xibo-player[4547]: player: …/…/src/xcb_io.c:259: poll_for_event: Assertion !xcb_xlib_threads_sequence_lost’ failed.
oct. 23 12:32:06 fst-o-f-xibo2 xibo-player[4547]: Player exited with code 5
or
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: [xcb] Unknown request in queue while dequeuing
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: [xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: [xcb] Aborting, sorry about that.
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: player: …/…/src/xcb_io.c:165: dequeue_pending_request: Assertion `!xcb_xlib_unknown_req_in_deq’ failed.
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: 0# signalStacktraceHandler(int) in /snap/xibo-player/50/bin/player
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: 1# 0x00007F69D49DDFD0 in /lib/x86_64-linux-gnu/libc.so.6
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: 2# gsignal in /lib/x86_64-linux-gnu/libc.so.6
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: 3# abort in /lib/x86_64-linux-gnu/libc.so.6
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: 4# 0x00007F69D49CF42A in /lib/x86_64-linux-gnu/libc.so.6
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: 5# 0x00007F69D49CF4A2 in /lib/x86_64-linux-gnu/libc.so.6
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: 6# 0x00007F69DB3C19DC in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libX11.so.6
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: 7# _XReply in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libX11.so.6
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: 8# 0x00007F69CFE3F194 in /var/lib/snapd/lib/gl/libGL.so.1
oct. 23 12:34:02 fst-o-f-xibo2 xibo-player[4547]: Player exited with code 6
second : dell 5060 micro with Intel HD Graphics :
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 0# signalStacktraceHandler(int) in /snap/xibo-player/50/bin/player
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 1# 0x00007F1507AD98A0 in /lib/x86_64-linux-gnu/libpthread.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 2# 0x00007F1427174D93 in /snap/xibo-player/50/gnome-platform/usr/lib/x86_64-linux-gnu/dri/i965_dri.so
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 3# 0x00007F142716F9BC in /snap/xibo-player/50/gnome-platform/usr/lib/x86_64-linux-gnu/dri/i965_dri.so
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 4# 0x00007F1427160C1B in /snap/xibo-player/50/gnome-platform/usr/lib/x86_64-linux-gnu/dri/i965_dri.so
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 5# 0x00007F14272D0558 in /snap/xibo-player/50/gnome-platform/usr/lib/x86_64-linux-gnu/dri/i965_dri.so
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 6# 0x00007F14272D05F5 in /snap/xibo-player/50/gnome-platform/usr/lib/x86_64-linux-gnu/dri/i965_dri.so
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 7# 0x00007F1508F871CC in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 8# 0x00007F1508FB7770 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 9# 0x00007F1508F87330 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 10# 0x00007F1508F9DAE6 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 11# gdk_window_end_draw_frame in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 12# 0x00007F15095CF9A3 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgtk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 13# gtk_main_do_event in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgtk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 14# 0x00007F1508F84765 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 15# 0x00007F1508F947F5 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 16# 0x00007F1508F959F6 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 17# 0x00007F1508F95BF0 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 18# g_closure_invoke in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 19# 0x00007F150822605E in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 20# g_signal_emit_valist in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 21# g_signal_emit in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgobject-2.0.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 22# 0x00007F1508F8DAC9 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 23# 0x00007F1508F79080 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgdk-3.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 24# 0x00007F1507F38D03 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 25# g_main_context_dispatch in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 26# 0x00007F1507F38650 in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 27# g_main_context_iteration in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 28# g_application_run in /snap/xibo-player/50/usr/lib/x86_64-linux-gnu/libgio-2.0.so.0
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 29# MainLoop::run(WindowGtk&) in /snap/xibo-player/50/bin/player
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 30# XiboApp::run() in /snap/xibo-player/50/bin/player
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 31# main in /snap/xibo-player/50/bin/player
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 32# __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: 33# _start in /snap/xibo-player/50/bin/player
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: ERROR: Caught a segmentation fault while loading plugin file:
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: /snap/xibo-player/50/usr/lib/gstreamer-1.0/libgstlibav.so
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: Please either:
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: - remove it and restart.
oct. 23 12:11:51 fst-o-m-bu-xibo xibo-player[7944]: - run with --gst-disable-segtrap --gst-disable-registry-fork and debug.
The third is a light client HP with Radeon HD 8280E i have mesa driver error :
Oct 23 14:23:01 dsi-player-1 xibo-player[3689]: libGL error: MESA-LOADER: failed to open radeonsi (search paths /snap/xibo-player/50/gnome-platform/usr/lib/x86_64-linux-gnu/dri)
Oct 23 14:23:01 dsi-player-1 xibo-player[3689]: libGL error: failed to load driver: radeonsi
Oct 23 14:23:01 dsi-player-1 xibo-player[3689]: libGL error: MESA-LOADER: failed to open swrast (search paths /snap/xibo-player/50/gnome-platform/usr/lib/x86_64-linux-gnu/dri)
Oct 23 14:23:01 dsi-player-1 xibo-player[3689]: libGL error: failed to load driver: swrast
Oct 23 14:23:01 dsi-player-1 player[4349]: g_dbus_proxy_new_sync: assertion ‘G_IS_DBUS_CONNECTION (connection)’ failed
Oct 23 14:23:01 dsi-player-1 xibo-player[3689]: [14:23:01.748] [4349] [error]: [GstMediaPlayer] Error from element sink: Failed to initialize OpenGL with Gtk
