Just to be clear you ran the task and it sent you the email automatically?
The first screenshot you showed looks like you opened the php file in a browser. While its good to check that this works, you want to make sure the task runs successfully on its own.
As long as the task ran the file and you got an email from that, your task scheduler is working and its not the problem.
You’ll want to set up your scheduler the same way - without the extra php-win.exe in your arguments.
Then the Windows Task should run.
The dataset will need to be used in a live layout
The dataset will need to have been changed since the last sync
I have done what you suggested but the result remains the same, xibo player shows the words “no data returned from the source” even though I have replaced the dataset with another one still the result is the same. Is there a possibility that this xibo program is not suitable for using the xampp program?
But I still thank you for your help
