Dev22
1
Currently I try to install Xibo (V1.7.5) in IIS 7. I downloaded PHP V5.5.3 and MySQL 5.7.10 and installed.
When I try to install, Xibo said me I need “MySQL support must enabled in PHP”. But in version 5.5.3 of PHP don’t exist “MySQL DLL”.
How can I to solve this problem ?
Thanks =)
alex
2
There’s full instructions for installing on IIS in the manual here:
http://xibo.org.uk/manual/en/install_environment_windows_iis.html
The project doesn’t directly support IIS however, so you may have more luck getting MySQL running on PHP on Windows on a forum specific to PHP.
