Problem with flip clock
Good evening!
I’m from Brazil and I have a problem when running the clock flip.
On the client it does not run with the effects only shows the clock .
What can it be?
You can try to click the ‘verify all’ button on Modules page in CMS and see if that changes anything.
What CMS/ player versions are you using?
I’m using version 1.7.4
The effect of clock works in the browser but does not work within the client , the clock appears but smaller.
which the necessary requirements for the flip work?
It might be the version of Internet Explorer that the client is using - there are instructions in the Manual for adjusting that setting and requesting the latest version of IE
