CMS 4.1.1 newly installed .
when I want to load media to library, I get the following message.
"SyntaxError: Unexpected token ‘<’, "<!DOCTYPE “… is not valid JSON”.
Help please !
Hi, what are you trying to upload? You need to ensure that the file type appears as a valid extension for the module. For example if I go to Modules under the Administration section of the main CMS menu and find Image in the grid, use the row menu and select Configure you can see and edit the valid extensions from here:
