the last two hours we tried unsuccessfully to update our Xibo CMS (docker on Linux) from version 2.3.6 to 3.0.0. According to the logfile of xibo_cms-web_1 this error occurs:
PHP Fatal error: Uncaught Error: Class ‘Slim\Middleware’ not found in /var/www/cms/custom/XiboForAndroidOnPremise.php:53
An update to 2.3.10 worked without problems. But even after that we can’t get to version 3.0.0.
Any Idea?
here is the log:
Status: Downloaded newer image for memcached:alpine
Creating xibo_cms-memcached_1 ... done
Creating xibo_cms-quickchart_1 ... done
Creating xibo_cms-xmr_1 ... done
Creating xibo_cms-db_1 ... done
Creating xibo_cms-web_1 ... done
docker logs --tail 50 --follow --timestamps xibo_cms-web_1
2021-06-25T07:43:46.064797020Z Updating settings.php
2021-06-25T07:43:46.080344364Z Generating RSA private key, 2048 bit long modulus (2 primes)
2021-06-25T07:43:46.159266545Z ......................................................+++++
2021-06-25T07:43:46.194530882Z .......................+++++
2021-06-25T07:43:46.194780168Z e is 65537 (0x010001)
2021-06-25T07:43:46.198208449Z writing RSA key
2021-06-25T07:43:46.247790339Z settingId
2021-06-25T07:43:46.247815199Z 1
2021-06-25T07:43:46.247818825Z Existing Database, checking if we need to upgrade it
2021-06-25T07:43:46.285002536Z Phinx by CakePHP - https://phinx.org. 0.9.2
2021-06-25T07:43:46.285146029Z
2021-06-25T07:43:46.285799219Z using config file .varwwwcmsphinx.php
2021-06-25T07:43:46.288390215Z PHP Fatal error: Uncaught Error: Class 'Slim\Middleware' not found in /var/www/cms/custom/XiboForAndroidOnPremise.php:53
2021-06-25T07:43:46.288409345Z Stack trace:
2021-06-25T07:43:46.288413052Z #0 /var/www/cms/vendor/composer/ClassLoader.php(444): include()
2021-06-25T07:43:46.288416130Z #1 /var/www/cms/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile('/var/www/cms/ve...')
2021-06-25T07:43:46.288419230Z #2 [internal function]: Composer\Autoload\ClassLoader->loadClass('Xibo\\Custom\\Xib...')
2021-06-25T07:43:46.288422648Z #3 /var/www/cms/custom/settings-custom.php(71): spl_autoload_call('Xibo\\Custom\\Xib...')
2021-06-25T07:43:46.288425556Z #4 /var/www/cms/web/settings.php(40): include('/var/www/cms/cu...')
2021-06-25T07:43:46.288428346Z #5 /var/www/cms/phinx.php(34): require('/var/www/cms/we...')
2021-06-25T07:43:46.288430970Z #6 /var/www/cms/vendor/robmorgan/phinx/src/Phinx/Config/Config.php(125): include('/var/www/cms/ph...')
2021-06-25T07:43:46.288433832Z #7 /var/www/cms/vendor/robmorgan/phinx/src/Phinx/Console/Command/AbstractCommand.php(266): Phinx\Config\Config::fromPhp('/var/www/cms/ph...')
2021-06-25T07:43:46.288556570Z #8 /var/www/cms/vendor/robmorgan/phinx/src/Phinx/Console/Command/AbstractCommand.php(93): Phinx\Console\Command\AbstractCommand->loadConfig(Object(Symfony\Component\Console\Input\ArgvI in /var/www/cms/custom/XiboForAndroidOnPremise.php on line 53
2021-06-25T07:43:46.291849094Z We will upgrade it, take a backup
2021-06-25T07:43:46.305954446Z mysqldump: Error: 'Access denied; you need (at least one of) the PROCESS privilege(s) for this operation' when trying to dump tablespaces
2021-06-25T07:43:52.597264946Z Running database migrations
2021-06-25T07:43:52.636437449Z Phinx by CakePHP - https://phinx.org. 0.9.2
2021-06-25T07:43:52.636523752Z
2021-06-25T07:43:52.637148490Z using config file .varwwwcmsphinx.php
2021-06-25T07:43:52.638876958Z PHP Fatal error: Uncaught Error: Class 'Slim\Middleware' not found in /var/www/cms/custom/XiboForAndroidOnPremise.php:53
2021-06-25T07:43:52.638898671Z Stack trace:
2021-06-25T07:43:52.638902266Z #0 /var/www/cms/vendor/composer/ClassLoader.php(444): include()
2021-06-25T07:43:52.638905242Z #1 /var/www/cms/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile('/var/www/cms/ve...')
2021-06-25T07:43:52.638908104Z #2 [internal function]: Composer\Autoload\ClassLoader->loadClass('Xibo\\Custom\\Xib...')
2021-06-25T07:43:52.638911542Z #3 /var/www/cms/custom/settings-custom.php(71): spl_autoload_call('Xibo\\Custom\\Xib...')
2021-06-25T07:43:52.638914360Z #4 /var/www/cms/web/settings.php(40): include('/var/www/cms/cu...')
2021-06-25T07:43:52.638917125Z #5 /var/www/cms/phinx.php(34): require('/var/www/cms/we...')
2021-06-25T07:43:52.638919820Z #6 /var/www/cms/vendor/robmorgan/phinx/src/Phinx/Config/Config.php(125): include('/var/www/cms/ph...')
2021-06-25T07:43:52.638922587Z #7 /var/www/cms/vendor/robmorgan/phinx/src/Phinx/Console/Command/AbstractCommand.php(266): Phinx\Config\Config::fromPhp('/var/www/cms/ph...')
2021-06-25T07:43:52.638973158Z #8 /var/www/cms/vendor/robmorgan/phinx/src/Phinx/Console/Command/AbstractCommand.php(93): Phinx\Console\Command\AbstractCommand->loadConfig(Object(Symfony\Component\Console\Input\ArgvI in /var/www/cms/custom/XiboForAndroidOnPremise.php on line 53
2021-06-25T07:43:52.642605786Z Importing ca-certs
2021-06-25T07:43:52.643260394Z cp: can't stat '/var/www/cms/ca-certs/*.pem': No such file or directory
2021-06-25T07:43:52.643891592Z cp: can't stat '/var/www/cms/ca-certs/*.crt': No such file or directory
2021-06-25T07:43:52.671043762Z WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
2021-06-25T07:43:52.683073424Z Setting up Quickchart
2021-06-25T07:43:52.707021179Z Configuring Maintenance
2021-06-25T07:43:53.188376537Z Removing web/install/index.php from production container
2021-06-25T07:43:53.226311628Z Starting cron
2021-06-25T07:43:53.226923449Z Starting webserver
2021-06-25T07:43:53.289292377Z AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 172.22.0.6. Set the 'ServerName' directive globally to suppress this message
You’ll also need to update your Middleware for your On-Premise license pack. You can download a fresh copy from Customer Portal in the license pool section.
ok, that problem is fixed, but we run into the next. the Browser tells me:
The CMS is temporarily off-line as an upgrade is in progress. Please check with your system administrator for updates or refresh your page in a few minutes.
That is what the log says:
> 2021-06-25T10:08:49.527868237Z up 20190806144729 2020-02-03 08:22:54 2020-02-03 08:22:54 AddShowContentFromMigration
> 2021-06-25T10:08:49.527930971Z up 20190823081448 2020-02-03 08:22:54 2020-02-03 08:22:54 AddImageProcessingTaskMigration
> 2021-06-25T10:08:49.527976262Z up 20190828123735 2020-02-03 08:22:54 2020-02-03 08:22:54 AddDefaultSettingResizeLimitResizeThresholdMigration
> 2021-06-25T10:08:49.528038236Z up 20190903083314 2020-02-03 08:22:54 2020-02-03 08:22:54 AddGlobalSettingForCascadePermissionsMigration
> 2021-06-25T10:08:49.528076745Z up 20190905084201 2020-02-03 08:22:54 2020-02-03 08:22:54 AddSettingForDefaultTransitionTypeMigration
> 2021-06-25T10:08:49.528141089Z up 20190905084642 2020-02-03 08:22:54 2020-02-03 08:22:54 AddSettingForAutoLayoutPublishMigration
> 2021-06-25T10:08:49.528177827Z up 20190910132520 2020-02-03 08:22:54 2020-02-03 08:22:55 DisplayMoveCmsMigration
> 2021-06-25T10:08:49.528255164Z up 20190917093141 2020-02-03 08:22:55 2020-02-03 08:22:55 InterruptLayoutMigration
> 2021-06-25T10:08:49.528307637Z up 20190918090608 2020-02-03 08:22:55 2020-02-03 08:22:55 AddDefaultSettingQuickChartMigration
> 2021-06-25T10:08:49.528382475Z up 20190919154513 2020-02-03 08:22:55 2020-02-03 08:22:55 AddNotificationAttachmentFilenameNonUsersMigration
> 2021-06-25T10:08:49.528431636Z up 20190926135518 2020-02-03 08:22:55 2020-02-03 08:22:55 AddSettingForTransitionAutoApplyToLayoutMigration
> 2021-06-25T10:08:49.528520061Z up 20190926140809 2020-02-03 08:22:55 2020-02-03 08:22:55 InstallSavedReportsAndSpacerModulesMigration
> 2021-06-25T10:08:49.528562431Z up 20191001092651 2020-02-03 08:22:55 2020-02-03 08:22:55 AddNotificationOriginalFilenameMigration
> 2021-06-25T10:08:49.528631934Z up 20191022101141 2020-02-27 20:37:02 2020-02-27 20:37:02 AddCommandEntityToPermissionEntityMigration
> 2021-06-25T10:08:49.528686455Z up 20191024152519 2020-02-27 20:37:02 2020-02-27 20:37:02 AddScheduleExclusionsTableMigration
> 2021-06-25T10:08:49.528760794Z up 20191122114104 2020-02-03 08:22:55 2020-02-03 08:22:55 FixDuplicateModuleFilesMigration
> 2021-06-25T10:08:49.528823533Z up 20191126103120 2020-02-27 20:37:02 2020-02-27 20:37:02 GeoScheduleMigration
> 2021-06-25T10:08:49.528893678Z up 20191126141140 2020-02-27 20:37:02 2020-02-27 20:37:03 RemoteDataSetCsvSourceMigration
> 2021-06-25T10:08:49.528949485Z up 20191205180116 2020-02-27 20:37:03 2020-02-27 20:37:03 AddPlaylistDashboardPageUserMigration
> 2021-06-25T10:08:49.529025901Z up 20200107082625 2020-02-27 20:37:03 2020-02-27 20:37:03 DisplayAddResolutionMigration
> 2021-06-25T10:08:49.529066885Z up 20200115115935 2020-02-27 20:37:03 2020-02-27 20:37:03 AddReportScheduleMessageMigration
> 2021-06-25T10:08:49.529143139Z up 20200122143630 2020-02-27 20:37:03 2020-02-27 20:37:03 AddReleasedRequiredFileMigration
> 2021-06-25T10:08:49.529188816Z up 20200122191232 2020-02-27 20:37:03 2020-02-27 20:37:04 AddCommercialLicenceColumnMigration
> 2021-06-25T10:08:49.529268678Z up 20200129104944 2020-02-27 20:37:04 2020-02-27 20:37:04 AddEngagementsStatsMigration
> 2021-06-25T10:08:49.529313386Z up 20200130165443 2020-02-27 20:37:04 2020-02-27 20:37:04 CountdownModuleAddMigration
> 2021-06-25T10:08:49.529405154Z down 20200311110512 AddIsDrawerColumnMigration
> 2021-06-25T10:08:49.529444068Z down 20200311110535 CreateActionTableMigration
> 2021-06-25T10:08:49.529529715Z down 20200319093235 ChangeInterruptLayoutMigration
> 2021-06-25T10:08:49.529575487Z down 20200401121544 AddSystemUserSettingMigration
> 2021-06-25T10:08:49.529672460Z down 20200407143200 AddCodeColumnToLayoutMigration
> 2021-06-25T10:08:49.529682682Z down 20200422101006 AddDataSetRowLimitMigration
> 2021-06-25T10:08:49.529761862Z down 20200427085958 AddReportScheduleStartEndMigration
> 2021-06-25T10:08:49.529801062Z down 20200530103029 DisplayRemoteLinksMigration
> 2021-06-25T10:08:49.529870640Z down 20200604103141 CommandImprovementsMigration
> 2021-06-25T10:08:49.529936348Z down 20200612141755 OauthUpgradeMigration
> 2021-06-25T10:08:49.529994748Z down 20200720092246 AddSavedReportSchemaVersionMigration
> 2021-06-25T10:08:49.530089088Z down 20200916134817 RemoveOldScreenshotsMigration
> 2021-06-25T10:08:49.530128118Z down 20200917140227 DisplayGroupCreatedModifiedDates
> 2021-06-25T10:08:49.530226335Z down 20201007080829 AddFoldersMigration
> 2021-06-25T10:08:49.530266208Z down 20201007093511 FeaturesMigration
> 2021-06-25T10:08:49.530327212Z down 20201025153753 RemoveOldPermissionSettingsMigration
> 2021-06-25T10:08:49.530389225Z down 20210105105646 AddMcaasScopeAndRouteMigration
> 2021-06-25T10:08:49.530474068Z down 20210113134628 EnableUserSharingFeatureOnUsersGroupMigration
> 2021-06-25T10:08:49.530518352Z down 20210201150259 UserOnboardingMigration
> 2021-06-25T10:08:49.530572210Z down 20210305131937 FixDuplicateTagsMigration
> 2021-06-25T10:08:49.530681695Z down 20210407111756 RemoveReportNameColumnFromSavedReportMigration
> 2021-06-25T10:08:49.530691292Z down 20210601104441 AddUserAgentToDataSetMigration
> 2021-06-25T10:08:49.530694710Z
> 2021-06-25T10:08:49.534843919Z We will upgrade it, take a backup
> 2021-06-25T10:08:49.681759129Z mysqldump: Error: 'Access denied; you need (at least one of) the PROCESS privilege(s) for this operation' when trying to dump tablespaces
> 2021-06-25T10:08:55.777475189Z Running database migrations
> 2021-06-25T10:08:55.817816715Z Phinx by CakePHP - https://phinx.org. 0.9.2
> 2021-06-25T10:08:55.817841090Z
> 2021-06-25T10:08:55.818701509Z using config file .varwwwcmsphinx.php
> 2021-06-25T10:08:55.820674948Z using config parser php
> 2021-06-25T10:08:55.821728943Z using migration paths
> 2021-06-25T10:08:55.822118645Z - /var/www/cms/db/migrations
> 2021-06-25T10:08:55.822334009Z warning no environment specified, defaulting to: production
> 2021-06-25T10:08:55.822378191Z using adapter mysql
> 2021-06-25T10:08:55.822388988Z using database cms
> 2021-06-25T10:08:55.840621565Z
> 2021-06-25T10:08:55.840969279Z == 20200311110512 AddIsDrawerColumnMigration: migrating
> 2021-06-25T10:08:56.128758975Z == 20200311110512 AddIsDrawerColumnMigration: migrated 0.2876s
> 2021-06-25T10:08:56.128787973Z
> 2021-06-25T10:08:56.128797664Z == 20200311110535 CreateActionTableMigration: migrating
> 2021-06-25T10:08:56.227624427Z == 20200311110535 CreateActionTableMigration: migrated 0.0986s
> 2021-06-25T10:08:56.227662840Z
> 2021-06-25T10:08:56.227667809Z == 20200319093235 ChangeInterruptLayoutMigration: migrating
> 2021-06-25T10:08:56.445637617Z == 20200319093235 ChangeInterruptLayoutMigration: migrated 0.2175s
> 2021-06-25T10:08:56.445673193Z
> 2021-06-25T10:08:56.445694595Z == 20200401121544 AddSystemUserSettingMigration: migrating
> 2021-06-25T10:08:56.465302568Z == 20200401121544 AddSystemUserSettingMigration: migrated 0.0194s
> 2021-06-25T10:08:56.465334163Z
> 2021-06-25T10:08:56.465633137Z == 20200407143200 AddCodeColumnToLayoutMigration: migrating
> 2021-06-25T10:08:56.698194895Z == 20200407143200 AddCodeColumnToLayoutMigration: migrated 0.2325s
> 2021-06-25T10:08:56.698232273Z
> 2021-06-25T10:08:56.698249506Z == 20200422101006 AddDataSetRowLimitMigration: migrating
> 2021-06-25T10:08:57.095519597Z == 20200422101006 AddDataSetRowLimitMigration: migrated 0.3971s
> 2021-06-25T10:08:57.095557919Z
> 2021-06-25T10:08:57.095590441Z == 20200427085958 AddReportScheduleStartEndMigration: migrating
> 2021-06-25T10:08:57.363677062Z == 20200427085958 AddReportScheduleStartEndMigration: migrated 0.2677s
> 2021-06-25T10:08:57.363714425Z
> 2021-06-25T10:08:57.363755874Z == 20200530103029 DisplayRemoteLinksMigration: migrating
> 2021-06-25T10:08:58.281626038Z == 20200530103029 DisplayRemoteLinksMigration: migrated 0.9178s
> 2021-06-25T10:08:58.281656908Z
> 2021-06-25T10:08:58.281841026Z == 20200604103141 CommandImprovementsMigration: migrating
> 2021-06-25T10:08:58.789425259Z == 20200604103141 CommandImprovementsMigration: migrated 0.5077s
> 2021-06-25T10:08:58.789461076Z
> 2021-06-25T10:08:58.789681435Z == 20200612141755 OauthUpgradeMigration: migrating
> 2021-06-25T10:08:59.261751198Z == 20200612141755 OauthUpgradeMigration: migrated 0.4721s
> 2021-06-25T10:08:59.261782017Z
> 2021-06-25T10:08:59.261786825Z == 20200720092246 AddSavedReportSchemaVersionMigration: migrating
> 2021-06-25T10:08:59.427038449Z == 20200720092246 AddSavedReportSchemaVersionMigration: migrated 0.1652s
> 2021-06-25T10:08:59.427068581Z
> 2021-06-25T10:08:59.427270282Z == 20200916134817 RemoveOldScreenshotsMigration: migrating
> 2021-06-25T10:08:59.447351174Z == 20200916134817 RemoveOldScreenshotsMigration: migrated 0.0192s
> 2021-06-25T10:08:59.447380037Z
> 2021-06-25T10:08:59.447384093Z == 20200917140227 DisplayGroupCreatedModifiedDates: migrating
> 2021-06-25T10:08:59.785410465Z == 20200917140227 DisplayGroupCreatedModifiedDates: migrated 0.3389s
> 2021-06-25T10:08:59.785439361Z
> 2021-06-25T10:08:59.785444323Z == 20201007080829 AddFoldersMigration: migrating
> 2021-06-25T10:09:02.781609428Z
> 2021-06-25T10:09:02.793822531Z In PdoAdapter.php line 134:
> 2021-06-25T10:09:02.793857141Z
> 2021-06-25T10:09:02.793872548Z SQLSTATE[22007]: Invalid datetime format: 1292 Incorrect datetime value: '0
> 2021-06-25T10:09:02.793875190Z 000-00-00 00:00:00' for column 'createdDt' at row 1
> 2021-06-25T10:09:02.793877785Z
> 2021-06-25T10:09:02.793880800Z
> 2021-06-25T10:09:02.793947718Z migrate [-c|--configuration CONFIGURATION] [-p|--parser PARSER] [-e|--environment ENVIRONMENT] [-t|--target TARGET] [-d|--date DATE] [-x|--dry-run]
> 2021-06-25T10:09:02.793953379Z
> 2021-06-25T10:09:02.799404321Z Importing ca-certs
> 2021-06-25T10:09:02.800122052Z cp: can't stat '/var/www/cms/ca-certs/*.pem': No such file or directory
> 2021-06-25T10:09:02.800714574Z cp: can't stat '/var/www/cms/ca-certs/*.crt': No such file or directory
> 2021-06-25T10:09:03.036045094Z WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
> 2021-06-25T10:09:03.048517497Z Setting up Quickchart
> 2021-06-25T10:09:03.072579473Z Configuring Maintenance
> 2021-06-25T10:09:03.548964339Z Removing web/install/index.php from production container
> 2021-06-25T10:09:03.625356263Z Starting cron
> 2021-06-25T10:09:03.626192830Z Starting webserver
> 2021-06-25T10:09:03.932488217Z AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 172.26.0.6. Set the 'ServerName' directive globally to suppress this message
and again we restored back to 2.3.6
After the first login it looked fine, but all layouts were black. No media was loaded from the library. I checked the library and found a lot of files, much more than before (10x more). The download from the library works, so the files are still there.
For example: We have one PDF with the current corona information. This PDF is often replaced by a new version. It looks like, that after the update, I see all versions of this file in the library. Same name, diffrent ID’s.
After the restore, our displays could load the files from the library, but not the text elemets. We had to checkout and checkin every layout, now it works.
