Problem Layer order (z-index) [1.7.2]
It’s there so it can be used if you need it. As I said, in almost all cases I can think of there’s no need to adjust the zindex of regions or the background. The z index is there in the XLF so there’s the option to modify it in the user interface, but that doesn’t mean you should change it. Just leave it as it is and things will work well.
