I’m looking at the manual now, it’s not clear when to this. https://xibo.org.uk/manual/en/manual_install.html
The point is that in version 1.8.9 this did not happen.
The folder continues to be created insistently in the root. this does not make sense.
And if I use the full address: public_html / mydomain.com / xibo / web / media /
All these folders above will be created inside the web folder: public_html / mydomain.com / xibo / web / public_html / mydomain.com / xibo / web / media /
That is not a fully qualified path.
You MUST use a fully qualified path (ie starting with a / or c:\
It worked perfectly now!
Thank you!
