CMS Version 3.3.3
Preview images in playlists are very small. When I need to replace an image, I have trouble knowing which one to change when multiple images are similar. I looked in the settings and I believe there is no way to enlarge the size of the previews. Has anyone had this problem and found a solution?
The only one I found is in the left menu, it is possible to click on the “play” logo and the images are bigger, but it would be really cool if someone had a solution to have a preview of a larger size directly in the playlist instead of the media tab.
Thank you !!
phiric
