I want to streamline the XIBO client PC build. Right now, I am rolling these out with 40 videos preloaded. Process is to build the basic PC with a fresh Windows copy, then install XIBO, then license it, then let it load the 40 videos.
Can I install and license the client, allowing it to create the XIBO folder, then copy the videos into the XIBO folder from a USB drive(these videos would be from an existing working player on the same CMS, so videos would be numbered properly, etc.), then let it go ahead and attach to the CMS and get the layouts etc., without having to have the CMS push out all the videos?
You can certainly try that. I’m not sure what the behaviour of the Windows client is when it has no reason to suspect a video would be in the Player library already.
I suspect he’s installing and regging a new client, the copy’s the library from an other client thats already configured.
Saving time when the new client has no need to download large media files over wifi.
I Think he need to make a layout thats uses local files like “c:\media” and copy this folder to the new clients.
Alex, you are correct. I copied only the video files.
installed client
registered client
approved client’
stopped network and client
copied video files only from another player (via usb stick)
restarted network and client
client locked up pc
What I’m attempting to do is streamline the build process without having to clone machines, change SID’s and all that fun. Maybe I’m trying to simplify too much…
My process:
build PC with WIn 10 Pro
rename and add to domain
Install XIBO client and register, approve
assign default layout that contains the required videos
It would be good if there is an easier way to clone the entire build? Suggestions?
