Thank you for your reply and screenshots. I can see in your embed screenshot that the URL you are using is the same as the original URL in your post. In the second document I passed on, it explains how to receive an embed link that you can use in an iframe. Looking at the URL in the example images in the document I passed on, it appears to say https://app.powerbi.com/reportEmbed
at the beginning of the address, whereas the address in your embed does not.
Did you try the method suggested in that guide or did you create that iframe yourself? If you created it yourself, please can you try the method described in the guide, as I suspect this could be why the content is not displaying correctly.
if this does not resolve the issue, you could also try adding the URl to the Edge Whitelist for your player, so it can use an alternative browser to load the content. To access the Whitelist:
- Log into your CMS and go to the Displays menu.
- Click the button at the end of the entry for your player and choose Edit from the menu.
- When the Edit Display window opens, go to the Profile Settings tab and add the URL to the Edge Whitelist field:
