KluthR
August 28, 2023, 8:53am
1
Windows
v3 R310
If I specify a start and end time during upload of an PDF for a playlist, the start/end range as well as the “delete after expire” are not stored! I have to specify it after upload to make it work.
That worked in 3.3.5 or earlier.
dan
August 29, 2023, 4:38pm
2
I believe you have to set those fields before you start the upload. Setting them afterwards would work for a subsequent upload.
KluthR
August 29, 2023, 5:19pm
3
Are you sure? I would bet I did it like always. But I give it a try tomorrow.
dan
August 31, 2023, 4:21pm
4
I couldn’t be 100% sure, but looking at how it does work, I am not sure how it could have worked the way you describe.
Regardless it should certainly be clearer how it does work and I have made a note of that.
KluthR
September 1, 2023, 6:18am
5
I just tested it again: Setting the duration before uploading the asset applies the settings!
system
Closed
December 1, 2023, 12:19pm
6
