Hi Xibo-Team,
we have seen, that our player wont respond the XMR-pushes anymore. Pressing “i” on the player shows XMR status: connected, but when we create or modify a calendar-event, nothing happens. Nothing appears in the “i”-status-window… We opened Wireshark and have seen there are coming data from the CMS (TCP, Port 9505) to the Player after modifying a calendar-event. But as written above, nothings shows up, nor does the player anything.
We have tried the follwoing:
- removed and re-installed the most recent player
- deleted everyting under “Documents”
- XMR reconfiguration (form CMS → Display settings)
- removed the Display from the CMS and re-inserted
Nothing helps. The only “solution” we found, is to reduce the “Collect Interval” to 1 minute. This will pull new things from the CMS. But the XMR-push doesnt work…
Sending (Windows)-commands from the CMS to the Player works immediately.
Docker-CMS: 3.0.6
Player 302.4, Win10
