Hi there,
I can’t find the difference between players (supported widgets) on the new website.
Exemple, on webOS, text widget not appears on the default Xibo layout.
Thanks for your help.
Hi there,
Currently, I use an archive of the old site : Content Management System | Xibo Open Source Digital Signage
Hi, thank you for posting.
This has been fed back to the website team to explore.
The updating of the User documentation is currently in progress and will include Player support to be detailed for each Widget, which should make it clearer.
Many thanks
