Hello
I have a question, I need a full screen on portrait mode. When I try to rotate the screen OS using an application from the play store, it will end up with a screen that stays on the landscape and appears in the middle of the system. I have to have the fullscreen system in height.
as was the case here:
I have a Lineage 14.1 on desktop PC.
If it is not, do you know any proven hardware (probably minix) when I buy a 100% work on full-screen portrait? Can be when xibo works in landscape and all content is portrayed. Images or videos I will rotate to portrait. There is a problem with other content (webpage, PDF, text… etc…)
