Hi
Please can someone help me
When i am trying to access my sql server via php my admin
it comes up php5.5+ is required
currently installed version is 5.3.28
Has some done an upgrade who can guide me through please .
thanks
Juan
Hi
thanks
Juan
What web server environment are you using please?
hi peter
IIS 8
I donβt really use IIS, but as far as I know you should be able to simply download new php version and extract it to a new folder then update IIS settings to use the new path for php.
I believe there is some php manager for IIS as well, which could be handy.
Perhaps someone who know IIS better can give you more information, alternatively, since itβs more IIS question than Xibo question, you can try asking on IIS forums.
