when people are using xibo they can find a way to force the taskbar to show up and close xibo with right click and then the close window button. is there any way to prevent them from closing xibo. like if they close it it inmediately pops backup again or a way to prevent them from accessing the taskbar at all.
ps: we are testing xibo in our office and people seem to like it.
If you are using 1.7.8/1.7.9 Xibo for Windows client.
It also comes with separate application called Watchdog, it should detect that Xibo was closed - on purpose or otherwise and restart it - unless someone will also close Watchdog from sys tray as well.
While it is possible to disable any key combinations (alt+f4, ctrl+alt+del etc or windows key) it can’t be done in Xibo itself, you’d need some application like AutoHotKey to remap/disable them.
